Tube Port Lengths
I was looking into tuning my enclosure a little lower, from 34hz down to maybe 28 or 30. I would probably be using 3 or 4" PVC. for 30Hz the 3" tube needs to be about 12" long (about the inside depth of my enclosure); for 4", 22.3". Could I use two tubes to achieve this length? Or will that cause the tuning to go wonky?
Too many projects, too little time...
Ok, do you think 3" would be too small? I'm worried about port noise down low. Subs are 2 Alpine S-10's, in separate chambers, about 1.5 cubes per. Current tuning is 34Hz with a 3"x9" tube per. Down low I get what I think is port noise from outside when the trunk is popped, not so noticeable from inside.
  • Who's Online   0 Members, 0 Anonymous, 2273 Guests (See full list)
