Here's some pics of my Mazda5.........so far it hit 151 dbs with only 4,000watts and it's a daily drive setup.......but i'm looking foward to build a ported box (Around 30hz)......but i only have 40" x 30" x 18" of space (NO WALL) I've be using 3/4 MDF for the enclosure.........Please give me our opinion before i start cutting........Where should the port be place? and Let's hope it works........Thanks bro :hi:
Front View
Back View
TEAM ELEVATION AUDIO
BassRace 140.0-149.9
My Ride
what equipment?
justin smith
1996 mercury grand marquis
20'' bentchi b7 lexani n3000 245/35/20
cactus 5kw at 1ohm dcr(beast)
2 18'' btl's in a 14.15^ft wall tuned to 35hz with 210'' of port
kicker zx650.4
componets in still the works
200amp motorcraft alt
xs power d3100 (beast)
kenwood ddx512 h.u.
you mean my EX? the one I dumped? just remember every time you kiss her that i used to cum in her mouth
and BTW your girl just called me....
pure pwnage
Rachet strap adds the debzz lol, id go sub up port back. basicly the same size enclosure your running now. what subs are those?
They are Elevation SQx and the amps too........but my 30" is up to the back window.......the port won't have space --> at least the port needs 6" minimum.....correct me?
My Ride
you def dont want to smuther the ports opening thats for sure. i plugged some numbers in and will those subs be ok at 1.3 cubes per woofer?
edit* it would probley be less than that i used 30
Edited by 97maxima
American Bass*DC Power
And what kind or size of port you recommend? because i was thinking all subs up, but the port between the first and second row of subs.....
My Ride
u might be able to get louder with less subs and proper air space :01nocomment8so: ...
x2
4 of those woofers might get louder than the 6 in the same space. you might have to break down and do a wall or a clamshell. unless your trying to stay out of that class.
