ok thanks bro yea i did all my trim pieces they look good nice and shiney i was gonna wet sand but i didnt want to mess them up so i left them alone they have a nice shine but hey i guess a 1500-2000 wet-sand cant hurt
new toy
97 chevy s10 ext cab
bagged
22s
system (coming soon )
4 soundstream t4-15s walled
2 concept 2410 mono amps
REFS
http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004
http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
Wet sanding with 1500 - 2000 grit is a good idea.
BUT
when you wet sand, your sanding the shine off the parts. Your doing this to make it as flat as possible.
Then you break out a rubbing/polishing compound and go to town even more to make it shine even better.
Be careful polishing with a powered tool. If you burn through into the paint, you will be pissed.
For the most part, the interior pieces do not need to be wet sanded and buffed if the beginning steps were done properly.
I have only ever done this to sub boxes and 1 dash. Everything else has been just fine with a clear coat only.
Building The Best.....Repairing The Rest
The bitter after-taste of a poor quality job will last far longer
than the sweetness of that cheap price!
ok thanks bro yea cause mine shine pretty good.. any ideas i did all them steps when i did it but i still have some grain in some of the pieces not much at all matby cause i used a shitty high build primer (dupi-color) not sure though???? the main one is my dash bezal any ideas like maybe putting on some resign ?????????????
new toy
bagged
22s
REFS
If you add resin, your just making more work.
If you still have some grain showing, you need to sand it more till it is all gone or mostly gone and use some more filler primers.
SEM and Evercoat make good ones. Much better than the Duplicolor.
trust me i did alot of sanding the door handles came out great there is slight grain that is hardly noticed (i notice cause i was lookin hard lol) maybe it was the primer but i plan on doing it in the winter cause im sound proffing my truck u got any pics of and blazers/jimmy wit interior pieces just paint also do u have any pics of 4 15's in a blazer or jimmy thanks
new toy
bagged
22s
REFS
well mine is basically done but i dont wanna do the dash so how much u wanna sell all the bezal pieces for
new toy
bagged
22s
REFS
  • 2 months later...
QUOTE
Originally posted by someone
what about painting the top dash what would the best process be to get paint to stick? and look good
If you want it just painted, follow the steps above to clean and prep it and then paint it.
I udnerstand the clean it part, self explanatory. The prep part, are you only referring to adding the adhesion promoter? So in other words you dont ever sand the dash if you want it painted.
Baylor University
Accounting
Prep part would be sanding it. And cleaning it again.
Sand it with some 80 to 150 grit, whatever your more comfortable with but don't go digging into the vinyl.
Then you need to clean it again.
Then filler prime it.
  • Who's Online   0 Members, 0 Anonymous, 1757 Guests (See full list)
