i didnt ask what it said on it, i asked what position it was in. the eq setting turns on the 3 way electronic crossover (active set up) and turns off the internal amp at the same time. Being you never stated if your front speakers are amplified or running off headunit power, that switch can cause you to not have crap unless your at max volume if they are running off the head....
its on th eq side. im running the speakers off the hu
2004 explorer xlt
HU: Alpine iva-w505
mids/highs: stock
Sub amp: american bass vfl200.1
Sub: dd9515
refs: t-roy
x2....if it's not that, then it's probably a couple of the speaker wires getting squished together back behind the head unit when its fully seated in the cage or you have a speaker terminal grounding out (if you replaced the stockers, that is). Have you tried to see if it happens with the head out of the dash but still hooked up?
yes. still does the same thing.
2004 explorer xlt
HU: Alpine iva-w505
mids/highs: stock
Sub: dd9515
refs: t-roy
Change it to norm....problem solved ;)
thank you very much. it works 100% now. that y i love the forum plenty of helpful people.
Edited by 99explorer
2004 explorer xlt
HU: Alpine iva-w505
mids/highs: stock
Sub: dd9515
refs: t-roy
