Jcoleman134 Posted May 30, 2009 Report Posted May 30, 2009 alright well my father has a 06 chevy equinox and today he called me up and said when he puts it in drive it doesn't go anywhere. well i went and looked at it and when putting it in reverse it has a hard clunk but then its fine backing up. but putting it in drive it doesn't go anywhere the check engine light is on, power decrese light and traction control light is on. now im pretty sure its obvious his tranny is bad. but why? its an 06 and he hasn't had any problems with it before. he has been in an accident before on the same side as the tranny but it never effected it.
97maxima Posted May 30, 2009 Report Posted May 30, 2009 sounds like a sensor that is located of the side of the tranny i cant remember for the life of me what its called. American Bass*DC Power
Jcoleman134 Posted May 30, 2009 Author Report Posted May 30, 2009 so you think it might not be as serious?
Jcoleman134 Posted May 30, 2009 Author Report Posted May 30, 2009 also when i put it in drive i can here something spinning like the flywheel or something.
Jcoleman134 Posted May 30, 2009 Author Report Posted May 30, 2009 alright well i went and checked it out this morning and its fine now. i'm guessing the sensor got wet last night from the big rain spurts we had. appreciate the help bro.
Jcoleman134 Posted May 30, 2009 Author Report Posted May 30, 2009 I hate to bring this back up. but it happened again but i was able to get it to go away so i could get to a OBD II reader. well it threw 5 codes. P0120- TPS/Pedal position sensor a circuit malfunction, P0171- System too lean bank 1, P0700- Trans Control System Malfunction , P1125-Manufacturers control fuel error metering, And P2138-TPS/Pedal Position Sensor/Switch D/E voltage correlation. Now thats pretty damn bad for a 2006. Im going to start with replacing the Throttle Position Sensor first and see if that helps any. But Anyone know what all im looking at here?
white4d96 Posted May 31, 2009 Report Posted May 31, 2009 Warranty? Too many projects, too little time...
GIMNICK Posted May 31, 2009 Report Posted May 31, 2009 sounds like u might have a wiring problem.... u did say it was wrecked right..... i would start by checkin that cause changin sensor cost shit loads of money and time hate... my 98 s10 throwed the same codes and all 5 in fact and i changed all kinds of sensors brain ect and it was a couple wire that was goundin out....just keep us updated on what u find out!!!
Jcoleman134 Posted May 31, 2009 Author Report Posted May 31, 2009 Warranty? I'm waiting for a call back now. sounds like u might have a wiring problem.... u did say it was wrecked right..... i would start by checkin that cause changin sensor cost shit loads of money and time hate... my 98 s10 throwed the same codes and all 5 in fact and i changed all kinds of sensors brain ect and it was a couple wire that was goundin out....just keep us updated on what u find out!!! alright i appreciate it. if its not under warranty then i guess ill go on the hunt.
