Darksideofsound Posted June 15, 2009 Report Share Posted June 15, 2009 ok, I have a 2006 dodge magnum, my battery is in the back, and I have done the 1/0 guage ground for my battery to my body.....then went to do the power, and the power is somewhere between 2 guage and 1/0....and it doesn't look like it comes straight off the alt under the hood, it looks like it goes into a computer before it goes to the back.... with all the hassle this could be, should I leave the factory guage power wire in there??? is the quality of the wire gonna be ok? engine ground to be done next... Link to comment Share on other sites More sharing options...
Canuheminow Posted June 15, 2009 Report Share Posted June 15, 2009 ok, I have a 2006 dodge magnum, my battery is in the back, and I have done the 1/0 guage ground for my battery to my body.....then went to do the power, and the power is somewhere between 2 guage and 1/0....and it doesn't look like it comes straight off the alt under the hood, it looks like it goes into a computer before it goes to the back....with all the hassle this could be, should I leave the factory guage power wire in there??? is the quality of the wire gonna be ok? engine ground to be done next... i have a 300c i think you can run it from the batt's in the back str8 to the alt! do you mean the fuse box up front? Chrysler 300 on 24's (2) audioque 2200d's [subs] (1) audioque 4x90 [highs/mids] (2) 12" DC audio level 4xl's (2) xspower D3100's Iraggi 320 amp alt Big 3, 2 runs of 1/0 guage Box 4 cft tuned to 30hz Link to comment Share on other sites More sharing options...
Darksideofsound Posted June 15, 2009 Author Report Share Posted June 15, 2009 i have a 300c i think you can run it from the batt's in the back str8 to the alt! seriously?? factory wire wouldn't do?? as you can see i kinda want someone to tell me its ok, so I dont have to replace that wire....LOL Link to comment Share on other sites More sharing options...
Canuheminow Posted June 15, 2009 Report Share Posted June 15, 2009 seriously?? factory wire wouldn't do??as you can see i kinda want someone to tell me its ok, so I dont have to replace that wire....LOL i dont see why you would need to Chrysler 300 on 24's (2) audioque 2200d's [subs] (1) audioque 4x90 [highs/mids] (2) 12" DC audio level 4xl's (2) xspower D3100's Iraggi 320 amp alt Big 3, 2 runs of 1/0 guage Box 4 cft tuned to 30hz Link to comment Share on other sites More sharing options...
velcroslap Posted June 15, 2009 Report Share Posted June 15, 2009 usually stock wire has way less of a strand count then 1/0 you would purchase. In other words less quality. * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic Link to comment Share on other sites More sharing options...
Darksideofsound Posted June 15, 2009 Author Report Share Posted June 15, 2009 usually stock wire has way less of a strand count then 1/0 you would purchase. In other words less quality. well, see now.....less quality is the trigger.....i will replace it.... Link to comment Share on other sites More sharing options...
Darksideofsound Posted June 15, 2009 Author Report Share Posted June 15, 2009 the wire comes off the alt, and on top of the engine it looks like an ecm or something, I'm gonna have to take a closer look before I start thinking the wrong thing... also, the wire that is coming off the alt isn't as big as the wire going to the back.... i will have to run inch by inch on the wire..... Link to comment Share on other sites More sharing options...
