davewms9605 Posted June 25, 2009 Report Share Posted June 25, 2009 Ok fellas, im starting over. Got a noob question. I see alot of cars, especially in my neighborhood(cleveland, ohio), with like 12 speakers ( for like 6 inch mids) in each door running off a 2 ch amp. My question is, is it safe to run these many speakers off a 2-ch amp? And if it is, whats the limit for lets say, a 800 watt 2 ch amp? Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
t-money Posted June 25, 2009 Report Share Posted June 25, 2009 (edited) Ok fellas, im starting over. Got a noob question. I see alot of cars, especially in my neighborhood(cleveland, ohio), with like 12 speakers ( for like 6 inch mids) in each door running off a 2 ch amp. My question is, is it safe to run these many speakers off a 2-ch amp? And if it is, whats the limit for lets say, a 800 watt 2 ch amp? it boils down to ohms. the amp cant tell how many speakers it has on it. it only see's the ohm load. so in theory u could run 100 speakers of a 2 ch amp if u could wire it to a ohm load the amp could run. and send enough power to. so safe? yes but not the most effective wy to go about things Edited June 25, 2009 by t-money Quote 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056 Link to comment Share on other sites More sharing options...
Lowroll Posted June 25, 2009 Report Share Posted June 25, 2009 it boils down to ohms. the amp cant tell how many speakers it has on it. it only see's the ohm load. so in theory u could run 100 speakers of a 2 ch amp if u could wire it to a ohm load the amp could run. and send enough power to. so safe? yes but not the most effective wy to go about things Yeah, and when you add more speakers you reduce the wattage to each right? bc i fought this for a while but i was told a 1200 watt amp will push a sub at 1200 watts, 1 ohm. but 2 4ohm dvc at 1 ohm would only get 600 watts each. Quote Current System: Pioneer 6900 HU Front Stage: (for now) Soundstream tarantula 5.25 in the doors Soundstream tarantula 4x6 in the dash Kenwood 400.4 for mids & highs Bass: 4 Soundstream RW-12's 2 Power Acoustik Stax 4000/1D's single chamber box, 2.65 cubes. Currently under the knife being bagged Rebuilding err'thang Link to comment Share on other sites More sharing options...
davewms9605 Posted June 25, 2009 Author Report Share Posted June 25, 2009 (edited) So, in theory, if i had 12-6 1/2' s rated at 4-ohms, running off an 800 amp 2-ch amp, this will make about 66 watts to each 6 1/2 right? How would i wire them? In parellel? Also, if this isnt the most effective way of doing this, what is, especially budget wise? Edited June 25, 2009 by davewms9605 Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
davewms9605 Posted June 26, 2009 Author Report Share Posted June 26, 2009 some insight people? Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
t-money Posted June 26, 2009 Report Share Posted June 26, 2009 (edited) well the problem is buget and car audio dont go together. the best way to do it is run 4ch's. but u can use the 2 ch. just gonna be hard to get alot of speakers wired to a safe ohm load for 2 channels Edited June 26, 2009 by t-money Quote 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056 Link to comment Share on other sites More sharing options...
t-money Posted June 26, 2009 Report Share Posted June 26, 2009 Yeah, and when you add more speakers you reduce the wattage to each right? bc i fought this for a while but i was told a 1200 watt amp will push a sub at 1200 watts, 1 ohm. but 2 4ohm dvc at 1 ohm would only get 600 watts each. is that 1200 rms? if so yes Quote 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056 Link to comment Share on other sites More sharing options...
t-money Posted June 26, 2009 Report Share Posted June 26, 2009 So, in theory, if i had 12-6 1/2' s rated at 4-ohms, running off an 800 amp 2-ch amp, this will make about 66 watts to each 6 1/2 right? How would i wire them? In parellel? Also, if this isnt the most effective way of doing this, what is, especially budget wise? if u could get them wired down to 4 ohms yes Quote 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056 Link to comment Share on other sites More sharing options...
davewms9605 Posted June 26, 2009 Author Report Share Posted June 26, 2009 if u could get them wired down to 4 ohms yes So, how could i wire them all to 4 ohms? Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
t-money Posted June 26, 2009 Report Share Posted June 26, 2009 So, how could i wire them all to 4 ohms? i dont think u can if u have to have 1 or 2 channels. u have to have a 4 ch. fuckin ohms Quote 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056 Link to comment Share on other sites More sharing options...
