fast85_gt Posted June 27, 2009 Author Report Share Posted June 27, 2009 If it's pure burpy numbers you want then build for 66hz. If you peak at 33hz you'll also peak at 66hz.Don't tune the box to your peak. Tune it a few hz below the peak, once you get it in the car the combined setup will peak a bit higher than the tuning. You need a bigger box and more port. Try to get 10 cubes after displacement with 180-200 square inches of port if it's purely for burping. Or 6 6" aeroports across the back of the box. thanks man im going to leave it a lone i was just hopeing to get a 150.xx maybe with the new alty when it gets here hope it will pick up 5tenths but i dont know im doing a 149.5 @28hz so im happy with it im just tired of plp doing a 150.00 @ 45 to 50 hz but i like the ground pounder thing thanks for all your help Quote Link to comment Share on other sites More sharing options...
