i have 2 18" treo ssx's and 2 rd audio 3250.1's strapped at 2ohms box is 9.99 net 7.77 gross port is 4"x25"x21.5"deep 100sqin port tuned to i think 33.05hz this is in a 97 ford probe ft (hatchback) best to date at a meca event is 149.5dbzzz@ the headrest btw when i done a sweep my car was peeking at 33hz same as the box's tuning i have a stock 90 amp alty and 2 hc2400's in the back soon to upgrade the alty and i have all the panels out off the hatch will putting them back in help with air flow i dont wont to make the port shorter becouse i like to see :hairtrick: :hairtrick: :hairtrick: :hairtrick: :shok: when i turn it up but i need to hit a 150.xx so please help me out here are some vids most of you have seen them but maybe you can see something to help me out i dont know if puting the panels back in will help or not my vids
Edited by fast85_gt
i think an upgraded alt will do wonders also try a stronger battery too
next time youre runnin hook up a volt meter and watch for voltage drops
edit:didnt see the 2 hc2400s but those arent gunna help too muc if your alt cant keep up
Edited by BIGD502
Ah, LoL.
Probes tend to suck for numbers anyway, don't take it to heart.
Buy an Explorer, LoL!
lol it must be the big ass dash oh well its good for ground pounding lol and haveing fun i guess every one the sits in it bails out for some reason
i seen a 10.8 at one time but on burps it only drops to around 11.8 or so but a new alty is in the mail
If it's pure burpy numbers you want then build for 66hz. If you peak at 33hz you'll also peak at 66hz.
Don't tune the box to your peak. Tune it a few hz below the peak, once you get it in the car the combined setup will peak a bit higher than the tuning.
You need a bigger box and more port. Try to get 10 cubes after displacement with 180-200 square inches of port if it's purely for burping. Or 6 6" aeroports across the back of the box.
10.x volts fo' life!
