1989 Dodge Ramcharger (2wd)
318
Overdrive
Tilt Wheel
AC/Heat (New hoses and new 134a freon)
New exhaust
New ECM
New front left tire, others are still in good shape also
Good paint, has some scratches on right rear where an axle fell on it, not too bad though
JVC KD-S690 headunit
Jensen 6x9's in the front doors and Soundstream SST6.9's in the back seat area
Kenwood 280w amp for the Jensen and Soundstreams
(2) Kicker comp 12's in a ported box (If you want you can take the box/subs/amp, or I can remove)
Jensen 300w amp for the kicker comp 12's
Here is what I know that it might need done.
1) New starter; sometimes the starter does NOTHING so I carry a hammer in the back and if you tap it 1 or 2 times it will start right up, just make sure you have something to tap it with.
2) Brake rotor/caliper on left front. Sometimes the front left brakes tend to stick and causes a vibration at 55+ and causes a slight pull to the left, normally fixes itself when using the brakes a few times or letting it cool off.
3) Driver seat needs redone; has tears in it
4) Fresh headliner, was done before grandpa passed away about 3 years ago
5) 2 interior lights in back seat area and cargo area don't work.
http://s112.photobucket.com/albums/n188/HP...nt=100_4166.flv
http://i112.photobucket.com/albums/n188/HP...25/100_4159.jpg
http://i112.photobucket.com/albums/n188/HP...25/100_4160.jpg
http://i112.photobucket.com/albums/n188/HP...25/100_4161.jpg
http://i112.photobucket.com/albums/n188/HP...25/100_4162.jpg
http://i112.photobucket.com/albums/n188/HP...25/100_4163.jpg
http://i112.photobucket.com/albums/n188/HP...25/100_4164.jpg
http://i112.photobucket.com/albums/n188/HP...25/100_4165.jpg
http://i112.photobucket.com/albums/n188/HP...25/100_3122.jpg
http://i112.photobucket.com/albums/n188/HP...25/100_3123.jpg
http://i112.photobucket.com/albums/n188/HP...25/100_3121.jpg
I am asking $1600 OBO.
Located in Martinez, GA.
I will get it cleaned up tomorrow, supposed to get my license. I will get it all washed, vacuumed, and detailed.
Have a good bit of parts laying around for it also
Breaking in a sub is like breaking in your girl before you pound her....
