i have had my system out of my car for a while but i hooked it all back up (07 camry)
i have a bad engine whine coming through my head unit . I also have a clarion preamp/eq that has a real bad ground noise also that i believe is just boosting the headunit noise. the only thing different from the time it was last hooked up is a 1/0 big 3. could that cause ground noise?
i am using the power from from the wires that came from the cigarete lighter adapter and the ground from my factory amp ground location.
when i took power str8 from the battery through a jumper cable the ground noise was considerably lower but still there
i have tried using different ground spots and i have tried grounding rca's along with trading them all out.when i ran rca from my other car str8 to the amp no noise. when i ran it to the eq noise.
any suggestion what i can try?
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
Where is your EQ grounded at? Ground it at the same place as the head unit, or try grounding it as the same place as your amp.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
i havent tried grounding it at my headunit but before i hooked up the eq i had a little noise coming through the head unit
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Try grounds first. Those are used as a last resort.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
I just tried grounding it to my head unit ground still have noise any other ideas
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Give me a schematic of what all you have. List it out from source back to the speakers.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
  • Who's Online   0 Members, 0 Anonymous, 1072 Guests (See full list)
