ARMYSGT_D Posted July 15, 2009 Report Posted July 15, 2009 i have had my system out of my car for a while but i hooked it all back up (07 camry) i have a bad engine whine coming through my head unit . I also have a clarion preamp/eq that has a real bad ground noise also that i believe is just boosting the headunit noise. the only thing different from the time it was last hooked up is a 1/0 big 3. could that cause ground noise? i am using the power from from the wires that came from the cigarete lighter adapter and the ground from my factory amp ground location. when i took power str8 from the battery through a jumper cable the ground noise was considerably lower but still there i have tried using different ground spots and i have tried grounding rca's along with trading them all out.when i ran rca from my other car str8 to the amp no noise. when i ran it to the eq noise. any suggestion what i can try? Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
lanman31337 Posted July 15, 2009 Report Posted July 15, 2009 Where is your EQ grounded at? Ground it at the same place as the head unit, or try grounding it as the same place as your amp. Quote 2 - Audiopipe AP30001Ds 1 - Lanzar Opti Scion 600.4 4 - Lanzar Optidrive 1232D's 1 - Lanzar Opti 5.1 1 - Lanzar Opti 6.1 1 - Lanzar Opti 6C midbass 1 - Alphasonic PCT6551 1 - Lanzar VX830 1 - JBL 22 band EQ 1 - Lanzar SDBT75NU 1 - AudioControl Epic160
ARMYSGT_D Posted July 15, 2009 Author Report Posted July 15, 2009 Where is your EQ grounded at? Ground it at the same place as the head unit, or try grounding it as the same place as your amp. i havent tried grounding it at my headunit but before i hooked up the eq i had a little noise coming through the head unit Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
ARMYSGT_D Posted July 15, 2009 Author Report Posted July 15, 2009 would a ground loop isolator work Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
lanman31337 Posted July 15, 2009 Report Posted July 15, 2009 Try grounds first. Those are used as a last resort. Quote 2 - Audiopipe AP30001Ds 1 - Lanzar Opti Scion 600.4 4 - Lanzar Optidrive 1232D's 1 - Lanzar Opti 5.1 1 - Lanzar Opti 6.1 1 - Lanzar Opti 6C midbass 1 - Alphasonic PCT6551 1 - Lanzar VX830 1 - JBL 22 band EQ 1 - Lanzar SDBT75NU 1 - AudioControl Epic160
ARMYSGT_D Posted July 15, 2009 Author Report Posted July 15, 2009 Try grounds first. Those are used as a last resort. I just tried grounding it to my head unit ground still have noise any other ideas Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
ARMYSGT_D Posted July 16, 2009 Author Report Posted July 16, 2009 anymore suggestions anyone Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
ARMYSGT_D Posted July 16, 2009 Author Report Posted July 16, 2009 i think ill ty the ground loop isolater next Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
ARMYSGT_D Posted July 16, 2009 Author Report Posted July 16, 2009 bump Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
lanman31337 Posted July 16, 2009 Report Posted July 16, 2009 Give me a schematic of what all you have. List it out from source back to the speakers. Quote 2 - Audiopipe AP30001Ds 1 - Lanzar Opti Scion 600.4 4 - Lanzar Optidrive 1232D's 1 - Lanzar Opti 5.1 1 - Lanzar Opti 6.1 1 - Lanzar Opti 6C midbass 1 - Alphasonic PCT6551 1 - Lanzar VX830 1 - JBL 22 band EQ 1 - Lanzar SDBT75NU 1 - AudioControl Epic160
