Okay so i was driving down the road and all the sudden my subs just shut off, I was thinking okay maybe my amp is just to hot because its pretty hot out today and my car is always outside, and i just checked to make sure that there is powergetting to it and there is im getting about 12.60v at an idle but no power through my speaker wires i mean i put the meeter to them and no reading but i wasnt sure if i'd get one does anyone have an idea ? oh and i have a Kicker zx400.1 amp
you metered your speaker wire or your power? im sure that amp has a light that should be on when the amp is on, check that. meter your power wire, check you fuse at the battery and if the amp has its own fuses chekc them too. check your ground
d(-__-)b
Im getting power from my Power wire and My ground but when i meetered my speakers wires from my amp i got nothing.
What was your speaker load?
he means what impedance ..... what are the voice coil configurations on your subs and how did you have them wired up...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Well i belive that are dual voice they are kicker 4ohm comps. but i figured it out the wires that went from my amp the the subs the plastic was in the amp part that screws down to connect the wire to the amp
