ground noise filter
where can i get a ground loop filter and which 1 do i get
Edited by ARMYSGT_D
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
If you HAVE to use one, then you have to- but you really should find the real reason for the ground loop. You are just putting a band-aid on a big wound.
Noise filters degrade the entire signal from your HU.
Make sure your amp grounds are clean.
Make sure your ground from your Alt to Batt to Chassis is large and clean.
Look for wires next to RCAs and Isolate them from one another.
For your HU, you really shouldn't use the factory ground from your vehicle's wiring harness- run a better one.
If you have a Pioneer HU, they are bad about having ground loops.
To fix it, wrap a small gauge wire around the shielding of the rcas where they connect to the HU and then run those wires to ground.
That will handle most RCA noise.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
im going to try rerunning everything 1 more time because i really domt want to use it.
i have triple and quadroople checked grounds and moved them i just cant figure it out
does it matter if the hu ground is longer than 3 feet?
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
i fought a ground loop on my dodge avenger for about a week. i finally figured out it was the antenna . the mast grounded on the rear fender and the cable was like 13 feet long. i ran a wire from the bottom of the antenna to my amp ground and that fixed 90% of it. i then grounded my headunit to the same spot and it was finally quiet.
  • Who's Online   0 Members, 0 Anonymous, 1143 Guests (See full list)
