h/u install question
I installed a alpine h/u in a 99 tahoe using the correct harness and now i have now sound from my rear doors but the speaker in the rear roof area and front doors works, anyone run into this before or have a suggestion?
He doesnt need that module. My 99 Denali had the Bose and I didn't need it. Not really sure why the rear doors arent working. Thats kinda weird. Good luck.
Credo Quia Absurdum
6 speakers, 4 outputs, so 4 speakers are working, get it?
gmos-11 is specifically for integrating into factory amps so the factory amp with its 6 outputs stays powering all 6 speakers like it should
or you can just put your own amp and speakers in
Team DC
ok i figured it out there is a pink wire that is a remote for the factory amp which lines up with the blue wire on the harness and i had it hooked to the power ant. wire on the cd player, i switched it from the power ant. wire to the blue/white remote wire and it works, so i guess the power ant. wire has a problem
  • Who's Online   0 Members, 0 Anonymous, 1301 Guests (See full list)
