puyallupn8ive Posted July 23, 2009 Report Posted July 23, 2009 I'm ordering a Fi BL and want to know when it ask if I want a hyper pole or want it universal, what does that mean? 98 Toyota Camry Eclipse AVN-6600 AudioControl 3.1 AudioControl Epicenter US Amps AX2000 US Amps MD-43 1 set Alpine type X components 1 set RF Power components 1 12" RE Audio XXX 220 Amp Iraggi Alt. Red Top (Front) Kinetic HC-600 (Back) Second Skin Damplifier Pro
thehoe92 Posted July 23, 2009 Report Posted July 23, 2009 hyper pole is for cooling definitely order it with if you are putting more than 1000 watts on it. universal is for recones. say you order a dual 2 ohm and get 1 amplifier now but in the future you want to get another 18 and power it off the same amp. if you want that 1 ohm load you will have to get 2 dual 1 ohm subs. since you already bought a dual 2 you can't get a recone for a dual 1 because the gap will be different. IMO people typically change subs when they want a new setup so I would just stick with the non universal. Wouldnt be thehoe92 without teh purple
puyallupn8ive Posted July 23, 2009 Author Report Posted July 23, 2009 hyper pole is for cooling definitely order it with if you are putting more than 1000 watts on it.universal is for recones. say you order a dual 2 ohm and get 1 amplifier now but in the future you want to get another 18 and power it off the same amp. if you want that 1 ohm load you will have to get 2 dual 1 ohm subs. since you already bought a dual 2 you can't get a recone for a dual 1 because the gap will be different. IMO people typically change subs when they want a new setup so I would just stick with the non universal. Theres already a cooling option for ordering, so that means hyper pole is even more cooling? 98 Toyota Camry Eclipse AVN-6600 AudioControl 3.1 AudioControl Epicenter US Amps AX2000 US Amps MD-43 1 set Alpine type X components 1 set RF Power components 1 12" RE Audio XXX 220 Amp Iraggi Alt. Red Top (Front) Kinetic HC-600 (Back) Second Skin Damplifier Pro
hdrox88 Posted July 23, 2009 Report Posted July 23, 2009 Click Check out Fi's tech section. It lists all the options for all the subs. You may want to post this Q in the right section for better response.
