How long does it usually take to break in new speakers also after breaking them in can you play them a little louder than usual cause im scared to go louder cause i might blow them.
What speakers are they and what are you powering them with?
they're Alpine SPS-609
-Coaxial 3 way Speaker System
-Haut Parleurs Coaxial 3 Voies
-260 Watts peak -- 85 Watts RMS
Powered by my Headunit which is a brand new 2009 JVC Aftermarket Radio
Will be getting an amp for the speakers sometime though
There's no possible way you can blow them out through your H/U!! Just get a good 4 channel amp and make sure the gains are set to the halfway mark..
2003 Mercury Marauder Black (R.I.P)
Tinted Windows
Purple HID's 10000K
Fog Light HID's 10000K
Swi Jack Steering Wheel Controls
Apple I-Pod Classic 80GB
Alpine KCE-422i Full Speed I-Pod Cable
Alpine IVA-W203/P1 Navigation/Bluetooth
Alpine PKG-M780 7' Headrest Screens
Alpine PXA-H701 Sound Processor
Alpine MRP-F300 4 Channel Amp
Rockford Fosgate 1501bd Power Amp
2 Kicker L7 15' Solo Barics
Alpine Type R SPR-17S Component's
Alpine Type R SPR-57C Coaxial's
Monster Performance RCA's
0/2 Gauge Wires
BIG III W/Fuse
200 Amps Custom Built Alternator
Yellow Cap Optima Battery Front
Xstatic Batcap 800 Back
Custom Mounted Bass Knob
LED's 2x License & Trunk Light
BoYo VTK-350 Color Backup Camera
Dynamat Xtreme Front Doors & Rear Deck
Clifford Matrix 50.7X Alarm System/Remote Start
I actually had the previous year model of those (SPS-69C2). They took a couple weeks of daily commuting for the tweets to settle down a bit. An amp will help them sound much better, and louder too.
Alright cool really appreciate it but do the popping noises come from the tweeters or the bass cause i think its the bass but im not sure
So even if they make these little pop noises when i start to actually turn them up they arnt messing up.
If not what do these pop noises mean.
Do you have a lot of bass going through them? You can drive them to over excursion and cause damage from blasting bass heavy stuff without the power to control them.
Is that 37 out of 40, or, between 37 and 40? Usually you should never turn your head unit all the way up. If it starts popping at 37 then dont go ever 36 :D You will do damage if you do that too much. Try using the EQ to give less emphasis on the lower frequencies. See how that works. If you want to go louder, get a good 4 ch amp to push them.
  • Who's Online   0 Members, 0 Anonymous, 326 Guests (See full list)
