Rear Firing Single Cab
iTech
Has anybody had any experience with Rear-Firing in Single Cab?
I plan on doing this or downfiring. The only problem with downfiring is the max bottom depth I can do is 12.5" so the 12" sub will be on the surface of the wood just barely. I'm worried it might not be enough support because that will leave about 1/2" on both sides of the Sub Hole.
(Where ever the sub will be, it will at least have 2 baffles.)
My Official Feedback Thread
PSN - tech2332
Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
I tried it once in a Ranger, and I was fairly impressed with the results. The only thing I didn't like was how severely the rear deck rattled.
As for sub support, as long as the entire flange of the basket is supported you shouldn't have any problems. While it may only be an inch of wood to adhere to, its only an inch away from the edge of the box which is an exceptionally strong area. You may want to use t-nuts however because the chances of a screw holding in such a small piece of wood isn't great.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
T-Nuts with the sub?
PSN - tech2332
correct, to hold the sub in. Might even have to sandwich them between layers of the double baffle in the very thin areas.
2001 Chevy Blazer
(2) SAZ-3000Ds
Rockford 600-4
  • Who's Online   0 Members, 0 Anonymous, 3339 Guests (See full list)
