bat/cap comp setup
Ok..I have a three caps laying around (total 4.2 f)...and I am planning to add a battery that I can remove easily.
In IDBL rookie class I can not run a second battery but I can have up to 5 f of caps. But in Bass Boxing I can have a second battery.
What I am thinking about doing is making a setup where between runs I can either put in the battery or the Caps EASILY depending on which event I am going to run.
now the questions...
Are the caps worth it in the IDBL
and
any other ideas on the best way to do this.
I was going to have the caps paralleled on a board with 2 ring terminals set up (or something like that).
The main power is going to go to a fuse holder in the back. and a wire with a ring terminal will be attached at the other end of the fuse.
then I will have a fused distro going to both amps with a wire with a ring terminal out of the front of that.
will also have another ring terminaled wire running to the ground.
then I can either drop in the battery or the caps depending on the event.
guess what..I have pictures of the idea. If my explaining was ....Crappy
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
  • Who's Online   0 Members, 0 Anonymous, 1058 Guests (See full list)
