I was going to say its a sony as a smartassed remark, then give a suggestion about using more fans, but looks like i dont need to, lmao
its going in my sig
lmao
which amp is it cause if its the one im thinking of you could pry off the red on the front and drill tons of holes and attatch fans but thts only if he isnt going for good looks
Could you tell me the model so I can look at it I'm curious which one it is.
not sure of model but im pretty sure this is it.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
Could be low voltage that is causing the amp to overheat faster.
What type gauge wire is he using?
2002 Toyota Solara SLE V6
Headunit - Pioneer DEH P3900MP
Door Speakers - Polk Audio db6501 6-1/2" 2-way
Component System
Rear Speakers - Polk Audio db691
Speaker Amp - DD C4b
Sub - 2 12" Alpine Type R's in a 2 @ 33hz
Sub Amp - DD M2A
Electrical - Big 3 - Stinger HPM 1/0 guage Wires, Optima Yellow Top Battery, 180/120 DC HO Alternator w/ MLA
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
refs: DC_Power_Kyle
Guest DC Power Kyle
x2 on the voltage... the wire and voltage play a huge part on those amps... my MRP-M1000 would always overheat and shut off when i had crappy electrical.
stock electrical, with a better batt. to chassis ground and block to chassis ground (soon to be alt to batt hot too). he's using (brace yourselves) 4 gauge jumper cable wire for his hot run from the battery to the amp.
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
