Quick Wiring Question
Yes, it's a postive and negative Make sure to us a low number fuse if you forgot the what wire is postive or neg. The best way I found to do what you want is to us a relay or toogle switch. To me you should only run three things off a headunit anything more us a relay.
So it would be alright to tap into the amp + and ground?
If so, if I accidentally put the ground to the + and the + to the ground will something bad happen lol?
Edited by Gregggg
2002 Toyota Solara SLE V6
Headunit - Pioneer DEH P3900MP
Door Speakers - Polk Audio db6501 6-1/2" 2-way
Component System
Rear Speakers - Polk Audio db691
Speaker Amp - DD C4b
Sub - 2 12" Alpine Type R's in a 2 @ 33hz
Sub Amp - DD M2A
Electrical - Big 3 - Stinger HPM 1/0 guage Wires, Optima Yellow Top Battery, 180/120 DC HO Alternator w/ MLA
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
refs: DC_Power_Kyle
You can but its not the best way.
Well its just lights, it shouldn't be taking away to much power right?
Component System
Sub Amp - DD M2A
refs: DC_Power_Kyle
I would personally use a relay so it only comes on with the amp.
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
Maybe I'll just do without the lights lol
Its too much of a hassle lol
Component System
Sub Amp - DD M2A
refs: DC_Power_Kyle
It's not too much of a hassle. If you just hooked it up to the amp, it would be on all the time (the lights draw too much power to run them off the remote wire).
15.4" widescreen
What it does:
Oh I forgot, if you hook it up backwards without fusing both wires you will frie it. If you have the postive and negative wrong.
lol I just thought I could run them off the amp power but it seem to be too much of a hassle lol
Thanks though 2loud4uboyz and everyone else who gave me input
Edited by Gregggg
Component System
Sub Amp - DD M2A
refs: DC_Power_Kyle
Dude take your time and hook up your neon lite. That what car audio is all about Learning and enjoying.
But I don't have a relay and you said it isn't a good idea to hook it up to the amp supply.
Component System
Sub Amp - DD M2A
refs: DC_Power_Kyle
  • Who's Online   1 Member, 0 Anonymous, 1474 Guests (See full list)
