WIRING AMP HELP!!
themoney8
ok i have 4 celestions 6.5' they are 8ohm...i have a celestion in each door along with AAPEX titanium tweeter witch is 4-8 ohm impedance... so basically i have one celestion and one tweeter in each door... the amp i have is a hifonics titan Txi6408 witch gives out 4 ohms: 85 watts x 4 chan. 2 ohms: 170 watts x 4 chan. my question is how would i wire this???? and is this a good amp????
Hifonics are some good amps (as far as I've heard). I've honestly never heard anything bad about them. Are your tweeters 4 or 8 ohms? If they are 8, you could wire the 6.5s and tweeters in parallel so the amp sees a 4 ohm load.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
  • Who's Online   0 Members, 0 Anonymous, 896 Guests (See full list)
