Shadow Works Posted April 8, 2007 Report Posted April 8, 2007 First Right Click my Computer, and go to properties then click advanced , and in the performance Box Thingy click on settings, Click on Adjust For Best performance or custom... WHen u click on Adjust for Best performance it makes windows xp look like 98 ... i dont mind that but u mind that then click on custom Deselect everything exept ,use visual styles on windows and buttons,and Use Comon Tasks in folders and Use drop shadows for trash labels on the desktop.. and it might make ur desktop blury if this happened just right click ur desktop click on appearance then click on effects make sure were it says use the following method to smooth the edges of screen fonts is set to Clear type then click ok.now click apply in the visual effects thingy. When its done click on advanced tab there. on the last thing were it says virtual memory, click change. Now wat this will do is it will use some amount of space on ur hard drive as memory when it runs out of physical memory. Change the Intial Size higher than it was ... put it at 2000. but the maximum size to 4000 now click set and click ok , until ur out of there. Now click on start and click on run. now in there type in Msconfig. Put the startup selection at selective startup. NOw click on the startup tab . now this is all the stuff that starts loading as soon as windows opens. click disable all.and click apply now u will have to restart.every thing that is there will still remain fully functional , so now that ur background tasks arent eating up ur memory ur comptuer will startup faster and run faster while gaming Quote
