-Jensen CD/DVD/MP3/WMA/iPod and XM Ready Receiver w/ Fully Motorized 7" Wide Screen
What model?
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
Jensen VM9311
Ok, good luck with the build.
15.4" widescreen
What it does:
which other 18" sub i could put in my car
AQ is really good, but little expensive
For an 18" that can handle 1000 watts or more, AQ is everything but expensive.
I thought you said you had $1000 dollars to spend??
Edited by tech2332
My Official Feedback Thread
PSN - tech2332
Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
yea, if i'm gonna get that AQ sub, will my amp gonna be good enough for this sub?
and can someone help me with build a box for 18" sub? or 15"? idk which one should i get
18" would be louder.
Your amp will push it, but not that great like ones I listed. If you wire the sub to 2 ohms you'll only be giving it 400 Watts RMS, (Probably alot less cause of impedance rise, and I bet it's overrated since it advertises it's "Max" power soo much)
You could try and use that amp and see if you'll like it. It should sound way better then current sub and box. (no offense to your setup)
Edited by tech2332
PSN - tech2332
