Hey guys
i just got a quick question about my car system that my dad and me set it up in car
here's what i got:
-Boss Audio 12" 1400W Dual 4-Ohm Subwoofer
* Sensitivity: 96 dB
* RMS Power Range : 700 Watts
* Peak Power Handling: 1400 Watts
* Impedance: Dual 4 Ohm
* Low Frequency response: 25 Hz
* High Frequency Response: 2200 Hz
* Diameter: 12 Inch
# Diecast aluminum basket
# Poly injection cone
# 160oz Magnet Structure
# 2.5" Voice coil
# Mounting Depth: 5-7/8"
-SoundStorm Monoblock 1200W
* Max Power @ 2Ohm: 1200W x 1
* RMS Power @ 4Ohm: 200W x 1
* Signal-To-Noise Ratio: 103dB
* THD at RMS Output: 0.01%
* Damping Factor: 125+
* Dimensions: 10"W x 2-7/16"H x 9-1/8"L
* 2 Ohm Stable
* Variable Low Pass Crossover: 40-150Hz
* Fixed High Pass Crossover (200Hz)
* Variable 0 to +18dB Bass Boost
* Variable Input Gain Control
* Power and Protection LED Indicators
* Thermal, Overload and Speaker Short Protection
* Line and Speaker Level Inputs
* Chrome Plated RCA Connectors and Screw Terminals
* Remote Subwoofer Level Control
* Frequency Response: 9Hz - 50kHz (+/- 3dB)
-Jensen CD/DVD/MP3/WMA/iPod and XM Ready Receiver w/ Fully Motorized 7" Wide Screen
i also have a 1998 Plymouth grand voyager, so i pretty much have alot of room in the back, and only 1 12" sub :sorry:
could you please help me set it up so it would sound really loud and shake my car
and if it good sub and amp i have right now?
Honestly if you want to get really loud your going to need more than that. The way that Ive always looked at things is this, if a company says a amp is "max xxxx watts" the amp is usually crap and wont put out anywhere near that. Its not 100% true but amps dont have a "max" wattage. Ive never heard of that brand amp, the sub is so so for entry level. Not saying you wont be able to get it loud but not sure you will be able to get it as loud as what your hoping for.
Either way though congrats on your first system.
Edited by B4SSB0Y
Car - 99 Neon Sport
Batt - 1 Redtop up front On 200A Excessive Amperage alt
Sub - 2 12" Kicker L7's in ~2 cuft @ 36hz each on a Xtant X1001 @ 1 ohm
Front Highs/Mids - JVC CS-FS6 and Infinity 6022i on Xtant A2002
Rear Highs/Mids - None
HU - Pioneer DEH-P8600MP
1/0 wire ran thru entire car aswell as big3
DB - 144.5 @ Dash.
As far as what subs to run, that all depends on your budget honestly. Not only that but you will need to be able to power the subs, and will need to be able to have a strong enough electrical system to back that up. Not sure how big you are looking at going with this.
Car - 99 Neon Sport
DB - 144.5 @ Dash.
On the whole thing or just subs & amp? Are you planning on building a box for the subs? Ported or Sealed?
What genre of music do you listen to?
i wonna try build box my self for 2 15" sub and get a 2 ch. amp
but i need help of choosing the right ones and little help on how to make a box
i listen to rap
Well seeings your new to car audio, I would probly go with something not cheap so to speak but best bang for the buck type of system. I know this has been done so many times but honestly heard one for the first time today and was very impressed.
What I'm thinking is two type R's in 5.5-6 cuft box tuned to 32 hz off like a hifonics bxi2006d, not sure if that amp puts out enough power for two of those but think it does. As for a box, other than the design they are fairly simple to put together. Once you decide what you can do as far as a budget, and what you have in mind; you can provide some dimensions and someone on here can provide you with a box design free or at a very low cost. Some will possibly even provide a "cut list" so all you have to do is measure, cut and put it together. If you have never done anything like this before you might want to start out with maybe a single 15 and a smaller amp, you can always get a second sub later and either build another box or run dual boxes. There are alot of things to think about in this, and depending on if your comfortable enough installing all this yourself, building a box yourself etc.
Also where are you located, maybe someone on the forum will be able to localy help you as far as box and things when that time comes.
Edited by B4SSB0Y
Car - 99 Neon Sport
DB - 144.5 @ Dash.
  • Who's Online   0 Members, 0 Anonymous, 1254 Guests (See full list)
