darren509 Posted August 26, 2009 Report Posted August 26, 2009 image @ http://onlinecarstereo.com/CarAudio/ImageV...odel=Alphasonik PSW912 here are the specs: Technical Specification Sensitivity: 95 dB RMS Power Range : 2200 Watts Impedance: Dual 2 Ohm Diameter: 12 Inch Features Dual Ohm Subwoofer Cast Aluminum Machine Cut Alpha Basket Motor Assembly Heat Sink Ultra Light 2-Layer Carbon Fiber, Kevlar Cone with Aluminum Dust Cap TLTF J-Surround Flat Progressive Rate Nomex Damper with Spiral-Woven Leads 8-Gauge Lug-Lock Input & Output Terminals Rated at 2200 Watts RMS 93dB Efficiency Frequency Response of 45Hz to 900Hz 200 oz. Triple-Stacked Magnet Dual 2-ohm 3" Voice Coils Mounting Dimensions Depth: 11 3/8" Through Hole: 10 3/4" Diameter: 11 1/4"
