Thai_lover Posted August 30, 2009 Report Posted August 30, 2009 sup yall Im new to the forum and dont know much about amps. i am looking for a amp or amps that would power my 4 memphis pr 12" sub thanks. 2005 Dodge Durango Stock Electrical Jensen VM 9212N
Guest Posted August 30, 2009 Report Posted August 30, 2009 first things first, welcome to the forum! hope you like it here. ok now that thats out of the way lol, do you have the old pr's with the single 4 ohm voice coil or the new ones with the dual 4 ohm voice coil? easiest way to tell is to look at the terminals on the sub. if there are 2 sets (4 terminals) then its the dual 4. if you see only 1 set (2 terminals) then its single 4. sorry if thats kind of confusing, i cant explain things too well
Thai_lover Posted August 30, 2009 Author Report Posted August 30, 2009 They are the dual 4 ohm voice coil 2005 Dodge Durango Stock Electrical Jensen VM 9212N
Guest Posted August 30, 2009 Report Posted August 30, 2009 ok then you can wire them like this to 2 ohms so you need 1000rms at 2 ohms. heres a few amps that i like in that power range. http://www.sonicelectronix.com/item_6590_K...r+ZX1000.1.html http://www.audioque.com/aq/AQamps2200D.htm cant remember any more amps since its 5:30am so my mind is kind of "out of there"
Thai_lover Posted August 30, 2009 Author Report Posted August 30, 2009 ok man thanks for your help so early in the morning 2005 Dodge Durango Stock Electrical Jensen VM 9212N
Guest Posted August 30, 2009 Report Posted August 30, 2009 ok man thanks for your help so early in the morning haha thats jetlag for ya , np man. bump this back up when everyones awake and youll get alot more help
