Positive wire from the front to the positive buss bar. Negative wire from the buss bar to the frame or chassis.
Really isn't any different than setting up a basic system, except you have more batteries in place.
To answer your earlier question about fuses to the amp(s). If the amp(s) do not have built in fuses then yes, you'd want them.. unless the amps are so close to the batteries there'd be no short. The fuses in the amps are to protect the amps. The fuses from the front battery to the back batteries are to protect the positive wire and batteries against any shorts. This is why you put the fuses as close to the batteries as possible.
I hope that helped out a little. I haven't ran fuses in such a long time, I'm starting to think I'm new to the scene again.
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
Ahh okay. So the negative coming off the battery bank has to be grounded. Then you ground the amp aswell?
It didn't really seem right when somebody told me the negative off the battery bank goes into the amp.
edit:
Oh...
this is what my wire says, I have #1.
So would I use a 300a fuse?
Why I'm asking, the wire/fuse guide says this..
Maximum Fuse Size
00 awg 400 amps
0 awg 325 amps
1 awg 250 amps
2 awg 200 amps
4 awg 125 amps
6 awg 80 amps
8 awg 50 amps
10 awg 30 amps
12 awg 20 amps
14 awg 15 amps
16 awg 7.5 amps
Edited by Gearstix
Let me try this again.
Positive wire from front > fuse > long run to back > fuse > back batteries buss bar positive
Ground from back batteries buss bar negative to frame. Wire from back batteries buss bar negative to negative input on amp.
Positive wire from back batteries buss bar to positive input on amp.
If you do not hook the negative to the frame/chassis of the vehicle, you'll not get a charge. If you do not hook the negative from the buss bar to the negative of the amp, you'll not get power to the amp.
I hope I worded that right. If not I'm sure somebody will correct it for me.
I got ya.
  • Who's Online   0 Members, 0 Anonymous, 3008 Guests (See full list)
