i dont know why . ill pst some pic in about 20 mins
it was the wire going to the altnator that i cut there was two wire comeing from the (+) on the battire. i am assuming that the battire, starter, and altontor are on curcuit.
battire one wire goes up to the jump start lug other i am guessen starter
that small red wire there is the one in ?
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://s375.photobucket.com/flash/player.swf?file=http://vid375.photobucket.com/albums/oo196/smokeypitbulls/004.flv"></embed>
some lil window flex http://s375.photobucket.com/albums/oo196/s...current=004.flv
Edited by SmokeyDog
~2006 chrysler Sebring~
~2 runs of 1/0 front to back~
~1/0 wire for "big 3"~
4 spl-hx 12'' dual 2
2 dtr 1.3400
3 c&d terminologies 1000s
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
custom dave the box guys box
new stuff on the way
Team
Soundstream
From what I can see it sorta looks like you cut your alt charging wire, could you get a closer pic of where you cut?
¿ǝɯɐƃ ǝɥʇ
Is the wire you cut, red about 8 guage in size and had a rubber boot where it connected to the alt, if so that was your charging wire, and now your car will be running only on your battery and your battery wont recharge.
Also the battery is connected to the starter directly from the battery, the other wire you(from the battery) see runs all your accesories.
battire is chargeing got a wire going from alt to battire pos. one from battire ground to sturt. one from battire ground to block. took just the wire off the alt all connections at battire are the same.
2 dtr 1.3400
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
Team
Soundstream
i did but i replaced it with the 1/0 i did that right. RIGHT!!!!! o man i hope so everything is working fine better in fact
2 dtr 1.3400
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
Team
Soundstream
Oh ok so you have the Big 3 done, well then as long as you have an upgraded wire going from the alt to battery you should be good, I would just make sure it is taped off, so it doesnt short on anything.
Edit: To your above post, yes you did it good, you didnt have to cut the wire but since you upgraded it didnt need to be there anyway.
Edited by CaptainzPlanetz
¿ǝɯɐƃ ǝɥʇ
ok thanks got nervus for a min. i was 99.9% sure i had it right, and its taped off.. i just was wondering where it went and if theres any affect on voltage with the extra wire just sitting there. even know theres no draw on it just awnsed my ? i think
2 dtr 1.3400
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
Team
Soundstream
Naw man you should be fine, also back to your original post I get all my terminals from Ace Hardware, or Home Depot, they have terminals up to 4/0 wire, I like to use 2/0 terminals for my wire as sometimes its a bitch to get all the 1/0 strands in the 1/0 terminals.
¿ǝɯɐƃ ǝɥʇ
i found with the 1/0 lugs if you put the wire in to the end and twist a few times it molds the wire to the shape of the cone then it just slides in like lil dick in a wet pussy
2 dtr 1.3400
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
Team
Soundstream
