When strapping two amps.....
When you link up two amps i know the "master" controls both amps, but what do you set the other settings like the L/P and subsonic filters at on the "slave" amp? Do I just leave them all turned down and adjust them on the "master" only including the gain?
'05 GMC Envoy
H/U: PIONEER AVH P4300DVD
Subs: (8) SA-12's
Amps: (2) SAZ3500d's
MECHMAN 270A Alt and 5 Batteries with lots of 1/0
Is this how I should wire my subs to a pair of 3500ds strapped to get 2 ohms?
Posted Image
If your dual 1ohm subs are wired like this and you strap the amps to them then each amp will see 0.5 ohm. I'm thinking you have each amp @ 2ohm cause I guarantee you'll notice a huge difference from a single amp @ 1ohm and a pair strapped @ 0.5 each.
