Sundownz, Rusty Need Your Help. Creating a Sub
IH8PunkRok
What kind of wire would i use for the coil?
what kind of glue should i use on the coil?
what constitutes a negative and positive lead for me to hook power to? <--- THIS ONE (like when wrapping the coil is the first end laid the negative and the final end the positive?)
how much wire should i use? is more better?
what determines ohm loads?
im mostly concerned bout the voice coil. the rest i will play with and change
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
wire... the best,,,
glue c.a glue..
negative will be grounded..
wire less better..(less space for current to travel...)
The set up your talking about would sound great in my Tahoe. Trade you my dog for it. He has one eye but that only makes for bad depth perception so hey so what if he is running into shit, look at it this way he is easy to sneak up ninja style on. (right side only)
</div>
wire... the best,,,
glue c.a glue..
all those questions are in regards to the coil. r u sure ca glue is what needs to be used to keep the wire on the coil?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
You use a resin on the coil.
thats more what i was thinking
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
i thought u ment on the entire sub...
</div>
What kind of wire whould i use for the coil?
read again please. thanks tho.
anyone know anything about microhenries? how much is a good amount. how many windings on the coil? how big should the coil be?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
need some help from some sub builders. or someone that has experience with making a coil.
i know nothing and need to know a lot. now this sub will not be up to par with most. in fact itll lose to most walmart subs but i want to experiement so i need a working driver.
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   1 Member, 0 Anonymous, 725 Guests (See full list)
