i just purchased a jl 1000 amp today. i hooked it up as a master amp and i'm getting .3 volts from the sub output. at the same volume, i measured the slave jl 1000 amp and it was getting 5 volts from the sub output. everything measured identical. i even switched the subs to different amps and got the same results. im thinking something inside the amp is wrong but wanted to check on here first.
JL doesn't support master slave configs so what do you mean master and slave do you have two of them?
The Shoe Maker without shoes!
  • Who's Online   0 Members, 0 Anonymous, 942 Guests (See full list)
