fox_racin4 Posted October 2, 2009 Report Share Posted October 2, 2009 alright i got the gain matching and all figuered out buttttttt i need a -3 db tone 60HZ or another tone i can use to set the amps with and also a place to find it! thanks Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
brewer_brewer Posted October 2, 2009 Report Share Posted October 2, 2009 http://realmofexcursion.com/downloads.htm Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt" Link to comment Share on other sites More sharing options...
fritosaregood Posted October 2, 2009 Report Share Posted October 2, 2009 alright i got the gain matching and all figuered out buttttttt i need a -3 db tone 60HZ or another tone i can use to set the amps with and also a place to find it!thanks why are you setting gains with a -3db tone? 0db tones Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
brewer_brewer Posted October 2, 2009 Report Share Posted October 2, 2009 ^^^indeed. i always set with 0 db. ROE has both, mostly 0 db though. Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt" Link to comment Share on other sites More sharing options...
fox_racin4 Posted October 2, 2009 Author Report Share Posted October 2, 2009 (edited) i was told -3 so was gunna go with that my sub settin goes from 0 ( odd) to 8 what should i have it at? will a 70 hz tone work? and for 3K it should be 77Vrms right? Edited October 2, 2009 by fox_racin4 Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
brewer_brewer Posted October 2, 2009 Report Share Posted October 2, 2009 0 to 8 is your gain setting. in a perfect world you would match that number to the preout voltage of your headunit. ie, if you headunit has 4.5 volts preout then you would set the gain to 4.5 volts. but other factors come into play such as voltage loss through rca's, not all songs have the same level in them, etc, etc etc. anyway the best way to do it is with an O-scope or at least with a DMM if you have one available. Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt" Link to comment Share on other sites More sharing options...
fritosaregood Posted October 2, 2009 Report Share Posted October 2, 2009 (edited) i was told -3 so was gunna go with thatmy sub settin goes from 0 ( odd) to 8 what should i have it at? will a 70 hz tone work? and for 3K it should be 77Vrms right? is it the gain that goes from 0 to 8? if it just a bass setting leave it a 0 i use 45 hz tones,but i use an oscope. if you using a multimeter i usually has a range of 50hz to 60hz ac volts. for 3k at 1 ohm it should be 55.8 volts. P=V^2 / r so V= sqrt(P*r) => V = sqrt(3000*1) = 55.77 volts Edited October 2, 2009 by fritosaregood Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
fox_racin4 Posted October 2, 2009 Author Report Share Posted October 2, 2009 have a dmm i will be spliting the rcs off so i will only have half the voltage threw each... 5 volt preouts so 2.5 to each amp correct? i was thnking of putting it at 4 so i dont need to crank the gains and still have room to turn it down when i would like Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
brewer_brewer Posted October 2, 2009 Report Share Posted October 2, 2009 with the 0 to 8 are you talking about the gains or bass boost? Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt" Link to comment Share on other sites More sharing options...
fritosaregood Posted October 2, 2009 Report Share Posted October 2, 2009 have a dmm i will be spliting the rcs off so i will only have half the voltage threw each... 5 volt preouts so 2.5 to each amp correct?i was thnking of putting it at 4 so i dont need to crank the gains and still have room to turn it down when i would like dont just guess with the numbers on the knob, use a dmm atleast. and an oscope if you can. What amp is it? Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
