well i installed my wiring to factory wiring "dumb, but someone stole my shit so i had to".
anyhow i installed everything correctly and re-checked it twice...
my HU will turn on once i hit the display button... show the time.. and shut off about 10 seconds later... it only ejects discs and beep when i push the display button...
nothing else...
suggestions ??
nothing else...
suggestions ??
What do you mean "installed my wiring to factory wiring"?
You cut the harness and wired to the factory wires directly without a adapter?
more info plz, car, H/U, Pics....
CAUTION!
POOR INSTALLATION MAY SHORT BOTH YOUR SYSTEM AND WALLET
when my old HU got stolen... the cut the factory plug so... i couldn't just get an adapter harness and just match the colors.. so i got the haynes manual and looked up each wire and see what it did..
its for a 2000 civic si coupe.. and the HU is a jvc kd-s100.. i'll try to get a video of the issue... :censored:
OK, np. Did you test stuff with a meter before hooking it up?
Haynes manuals are OK for wiring, but I don't have much experience with them for car stereo..... I like the12volt
Here is the stereo wiring chart from the12volt.com
2000 Honda Civic Stereo Wiring
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
also check ALL of your fuses. Inside acc fuses as well as fuses under the hood because they may have shorted something when they jacked your old stuff and blew a fuse and now the H/U is only getting one of the two powers.....
Edited by HaMSaMMiCH
CAUTION!
double check all the wires are going to the correct place, as well as connections. Solder is ideal, but if not use butt connectors. NEVER wire nuts or only electrical tape, they make bad connections and will shake apart. If you have access to a multimeter check that you are still getting power on the switched 12v+. if it shows the time with the display button and ejects discs it is getting constant power. Sounds like switched is missing....
CAUTION!
well i used butt connectors and i triple checked the wiring.. its not it... i'm gonna disconnect it and just run it straight to the battery and try...
i did the multimeter with the yellow and it was showing okay.. and i checked the ground and its good... guess i could check the red power wire.. HMMMMMMM !!!!
i would double check that red wire you might have taped into a wire that shows up 12v for a certain time and then goes off.
vehicle-02 toyota celicawoofers-groundshaker g-s1 10" woofersamp-SUNDOWNAUDIO SAZ 3500battery-1 C&D battery
  • Who's Online   0 Members, 0 Anonymous, 1570 Guests (See full list)
