do a vent 14.5x3x9.29 that will be 38 hz after displacement
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
Okay so you will have roughly 4.170 ft3 after sub and port displacement. I would suggest doubling all your walls by adding a 3/4" mdf to all walls externally if you have room. If you don't have room you'll need to shrink the internal dimensions, but assuming you do we end up with 4.17ft3. In Meade's box you have two square ports so to do two sqaure ports and tune to 38 hz they will be 2 x 13.5 x 21.
ok i understand that, but i never understand how you get how long that L-shaped piece at the back needs to be! that is the part that confuses the hell out of me
18's in a wall to come....Its not all about the posts....check the member #...
