Alright I have two 15" Kicker L7's I was thinking of getting two Kicker ZX 1000.1 i mean i like to keep it all kicker but if there is a cheaper amp i can get that will sound just as good and push the subs just as well as that would I'd like to know.
Instead of 2 amps, think about 1 mono amp and wire the 2 subs together which would drop the amp down to 1 ohm.
I like running 1 amp per sub in set-ups using only 2 subs, it helps keep the rise down.
¿ǝɯɐƃ ǝɥʇ
So your saying its a good idea to run to amps ?
IMO yes, not too hard either, it may be a bit more expensive, but I think it will perform better than a single 2K rms amp.
And in your case all you have to have is a run of 1/0 to the back, with a distribution block and run the 1/0 in and a run of 4 gauge to go to each amp.
¿ǝɯɐƃ ǝɥʇ
yeah i get dealer cost on everything i order my amps are 400 a peice and im getting a HC1400 for like 150$ and my wires are really cheap . but yeah its gona pound icant wait= ]
