tacomabanga1986 Posted October 21, 2009 Report Posted October 21, 2009 i need help on tryin to diagnose whats causeing my cuzins lights to hella dim, its a 2000 somethin lexas ls300 and said that she took it to a few shops n they checked the alt n said it was good, that was my first thought was a bad alt, n then shes got a factory battery with factory shit terminals n was wondering if thats wut it is we live up close to the mountians n she works in the mountians n it might halfto do with cold weather but i unno she said it would crank up fine but when she starts driveing it would jurk n then cut off, she thinks it might be a timeing issue but i unno, im a jack of all traids but a master of none so i come to the great smd so see if yall might kno of why its doin this i need somewhat of an answer ASAP cause she gunna be here in 10min n ive checked everything n i dont kno would corroded battery terminals cause a car to cut off? here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
keepinitloud Posted October 21, 2009 Report Posted October 21, 2009 I think that would be a good start check the terminals and check the wires sometimes if the terminals are coroded it can travel back up the wire worked on astro van thought the starter went out put a new one in still wouldnt start went back through everything to see if i had missed something eventually I checked the ground wire and positve did a resistance test found the power wire was bad put a new one on put the old starter back on the van fired right up 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
tacomabanga1986 Posted October 21, 2009 Author Report Posted October 21, 2009 ya i was thinkin terminals too, she said it would crank fine but when she drove it the lights dimmed n the car shimmied n cut off, that makes me think alt but she had it "checked" and it checked out fine n i put my dmm on the battery n it was around 12.9v n then had her crank it up n it went to 14.x and was fine she said her tail lights more flashed than dimmed n im thinkin somethin along the lines of an alt problem to make it do that or feedback threw starter but i unno i tryed tellin her im not a mechanic but it dont work here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
