edog Posted October 24, 2009 Report Posted October 24, 2009 I have 3-amps in my truck 1 is for my seperates in my doors ,the other two are for my subs.It plays fine until I put the rca's into the sub amps then I get engine noise.I have the seperstes amp grounded in a different spot than the sub amps ,could tha be it or could it be something else? 2001 Southern Comfort Suburban sittin on 26"s Eclipse 6620 double din head unit (2004 dash mod) 4-AQ 3500D amps @1 ohm 8-Cadence 6.5 midbass 4- in each door. Image Dynamics Cd 1 pro HLCD 4-runs of KnuKoncepts 1/0 power wire 4-DC AUDIO lvl 4 xl 18"s in a wall 2-MECHMAN 270 AMP alternators(2 more on the way)xs power VCM 7-Deka intimidator group 31 batts(soon to be Xs power) 2-Rockford Fosgate Prime r300.4(1 bridged on mids, 2nd on CD1 horns and rear door speakers) 1-Rockford Fosgate 360.2(operated by Palm tungsten T5)My link
Guest Posted October 24, 2009 Report Posted October 24, 2009 make sure the ground is bolted to straight metal and not paint. try grounding your RCA's also.
