I have 2 10" Kenwood kfc w2512 and i have them hooked up to a kicker 300.1 amp, but i wanna get a bigger amp. I wanted to get some opinions on how big of an amp i could get and what kind to get. Heres a link of the specs of the subs.. http://www.crutchfield.com/p_113W2512/Kenw...tures_and_specs
Thanks!!
2012 Civic Si Coupe
- Nada lol
3d7304fe.jpgDCSig.jpgaol.pngYoutube
do you know what ohm load you are running them at?
for lower end subs like yours, i wouldnt go much over rms. so when you pic an amp make sure it doesnt go higher than 700wrms at the ohm load you are presenting. like if you were at 2ohms, a sundown 1000d should work pretty well but if your at 1ohm itll give them a little too much power.
no one likes to chime in on these questions unless you give more info. mostly how much you want to spend.
use this. http://www.the12volt.com/caraudio/woofer_configurations.asp
or use a DMM and set it to ohms then check the speaker wire at the amp.
almost every amp puts out different power and different ohm loads. so you could buy a 2000w amp but have your subs wired to 8ohm and only be getting 400w out of it.
feel free to pm me if you need more help.
Edited by skittlesRgood
not even close. that amp only puts out 340w. look at the RMS rating. NEVER care about its max rating. so that amp will only give each sub 170wrms at 4ohms.
with that amp you would be giving each sub 85 watts
where did you learn math??? lol
oh by the way. NEVER BUY SONY CAR AUDIO PRODUCTS!
  • Who's Online   1 Member, 0 Anonymous, 1478 Guests (See full list)
