i know this is kind of a noob question but i have a friend that wants to run 3 amps that put out 300 watts at 2 ohm instead of 1 amp that puts out 1000 watts at 1 ohm
i was saying that that would pull my amps from the front battery and he said it wouldnt i may be wrong so please correct me if i am
also he was saying that if he got 3 amps it would be louder and i said it might make it sound cleaner but probably not louder once again correct me if i am wrong
he has 3 re sr type 12s they are 300 rms and a 600 peak
any feedback on this is really appreciated
a single class d amp would be easier on the vehicles electical
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
I dont think it would matter how many different amps there are. 1000 watts is going to pull about 100 amps, depending on efficiency and shouldnt matter whether its coming from 3 amps or 1 amp
I'd hit that so fucking hard whoever pulled me out would be King of England.
Lol... looks like we were on the same page. Car-B-Ques suck.
ya, tires and paint burning make the marshmallows taste funny.
giving most 300w amps do 150+rms it would still be better to run a 1000w amp @2ohm or get him a cheap kicker kx1250.1 that does 1200@2ohm n try dat, but ied run a good 1000w amp @2ohm but giving independance rise he'll prolly get 3ohm out of amp so i unno
but ya 1 amp is alot better than 2 diff ones, and they wont be phaseing issues either due to tryin to set 3 gains, ive ran subs like this befor n it worked n sounded decent but not the best way to go, the less wire u can run the better, tryin to split a 4guage or even a 1/0 tryin to go threw 8guage wire back n forth, ited be better for one amp to run 3 subs than 3 amps one amp per sub daily
in the long run he's prolly only runnin 500rms total out of his setup now due to small amps, even most good 300w amps dont do 300rms so ya one amp is alot better, atleast it will be devided amongst the subs than tryin to set each amp
i kno steve has multi amps on multi subs but his setup is diff, he runnin one amp per coil so i dnt think this dude can do dat
ask him why he dont get one more 12 n run 4 off a good amp @1ohm?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
i think he doesnt want to buy another one because he doesnt want to spend a lot of money on this and he thinks buying 3 amps will be cheaper than buying one and i told him buying 3 will be more expensive then one... any thoughts on this also?
if impedance is a problem.. he can look into a jl1000/1 or pdx 1000.1... they do 1000rms at 2 and 4ohms and everything in between...
3 Kinetik Hc2000's
Dual 200amp alts.
and yeah buying one bigger amp is normally cheaper than buying 3 smaller ones
3 Kinetik Hc2000's
Dual 200amp alts.
