i feel like a total jackass, i am having big problems with my amp, i have a soundstorm labratories 1600 watt 2-channel powering 2-kicker cvx 12's, the subs are rated for 750 rms and 1500 peak, when i bridge my amp it will shut off after it hits hard a couple of times, i dont have this problem until i bridge my amp, i have now clue what is going on, i checked fuses, i have a good ground, i have a good power connection, i have my rcas run correctly, and remote is good so ...
99rangerkid
Posted (edited)
What ohm dual 4 I'm guessing? You prolly have them wire down to one ohm. Most amps when bridge don't like to go below 2 ohms. Some amps do and IDK if yours does but does your voltage drop at all when this happens?
Edited by etaks_crew
Technical Specification
RMS Power Range : 750 Watts
Peak Power Handling: 1500 Watts
Impedance: Dual 4 Ohm
Diameter: 12 Inch
Features
Nominal Impedance: Dual 4-Ohm
Resonance Frequency: Hz 26.4
Power Handling Peak: 1500 Watts
Power Handling RMS: 750 Watts
Total Q-Factor: 0.36
Equivalent Volume: 2.3 ft3
Outer Frame Diameter:12-9/16"
Hole Cut-Out Diameter: 11 1/8"
Mounting Depth: 6-5/8"
Priced per speaker
99rangerkid
Since they are 4 ohm subs, you can either wire the coils in parallel which will give you a 1 ohm load, or you can wire the coils in series and get a 4 ohm load. If I was you, i'd invest in a better amp that is stable to run at 1 ohm. But you're amp is going into protect because you're trying to push it too much & probably because of your electrical too, i'd try to upgrade your big 3 and see if that helps
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
So I think the reason your voltage drops is the extra draw you've created by bridging your amp plz someone correct me if I'm wrong. I don't think your amp will do one ohm bridged. If it will, then first thing I would do would be the big 3 to try and get rid on some of the voltage drop. The amp could be shutting down due to lack of enough power but my guess is that your amp wasn't meant to do one ohm bridged.
  • Who's Online   0 Members, 0 Anonymous, 2309 Guests (See full list)
