jagblazer01 Posted November 2, 2009 Report Posted November 2, 2009 What is your guys input on this....New build is gonna consist of 20-24 woofers in a clam shell. each sub is 500rms each. Is it better to try and run all woofers on one big amp or should I do a multiple amp setup? or does it not really matter? Team Sundown Audio / Team XS Power / Team SHOK SMD Super Buyer/Sellerwww.sundownaudio.com www.shokindustries.com www.4xspower.com www.excessiveamperage.com
stetsom rep 1 Posted November 2, 2009 Report Posted November 2, 2009 What is your guys input on this....New build is gonna consist of 20-24 woofers in a clam shell. each sub is 500rms each. Is it better to try and run all woofers on one big amp or should I do a multiple amp setup? or does it not really matter? With the advent of small Big Power amps I would suggest the use of one amp, just in the shock factor alone it would be cool. When you use multiple amps you have to match them with one amp its set it and go....20 subs would be a nightmare to wire to one amp but there are a bunch of amps that make over 10kw rms out there to run your set-up. Just my .02 12 Volts Baby!!!! Team Stetsom USA Team Stinger Team RENOTS Db-Drag World Finalist 05,06,08,09 Maryland State Record Holder 05,06,07,08,09 2009 Certified Score 161.0 Db-Drag SS 1-2 NSPL Maryland State Record 06,07,08,09 443-623-4952
jagblazer01 Posted November 2, 2009 Author Report Posted November 2, 2009 hi steve lol Team Sundown Audio / Team XS Power / Team SHOK SMD Super Buyer/Sellerwww.sundownaudio.com www.shokindustries.com www.4xspower.com www.excessiveamperage.com
CaptainzPlanetz Posted November 2, 2009 Report Posted November 2, 2009 I would do multiples, or else IMO you are gonna have rise like no other. Plus I dont even think you can wire 20 woofers to one amp. I would say do like 5 amps, 1 amp per 4 woofers, or you could do 1 amp per 2 woofers, the latter 2 would be most efficient IMO. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
