Guest Dave Posted November 3, 2009 Report Share Posted November 3, 2009 you said they don't do it all the time? could you make a video so we could try and hear what your hearing this motorboatin sound i could try to make a vid for ya. it only doe3s when im at idle or i have my headlights on or a/c on. the best way to explain it, is it sounds like a sub bottoming out but it isn't. i think i need more juice for my system cuz i checked all of my connections. that was the problem last time. the only thing i can think of now is that i have this upgraded alt, its letting the amp breathe better sao now its drawing more. the voltage drop could make the amp clip i gues thats what clipping sounds like. ive never heard an amp clip. so i dont know what it would sound like. the gains arent cranked either. they are turned as far down as they can go Quote Link to comment Share on other sites More sharing options...
Dustin Posted November 3, 2009 Report Share Posted November 3, 2009 (edited) hey i have this propblem its happened before but i solved it now im kind of lost the enclosure specs are right. last time when i fixed it, it was a power prob(loose connection to the battery) now im a lil lost. ok when i ha d this problem last time if i turned it up to loud(i have the amps set right the subs are powered at the rms rating)the speakers would rattle kinda like they were bottoming out but the arent. I think theycall it motorboating or at least thats what my boss at the shop told me. i know it happens whenthere is either a loose connection or lack of electrical power.when i got the truck(chevy below) the dumbass had a honda car battery in it and it would do the same thing. now i have an upgraded 200amp alt(still not enough juice) and it is starting to do it again and it quit for the longest when i got the alt. could it be because of the duralast battery cuz its not a comp batt like kinetik? plz help im trying to avoid bying a kinetik cuz of the price right now. should i jusat get a dual alt setup would that prevent it. I know i just probably answered my own question just now but i just want some feedback on it if any one has experienced this problem as well.and if there is a way to prevent cost effectively. i do not like optima i think they are way overrated try checking the altenater wires maybe you over looked something if i was you i would buy a couple of capacitersto help with the bumping from the speaker.now you quoted the your speakers was knocking well if you have a pretty good gauged wired running on the inside of the box it could be the bass from the speaker knocking the wire around because i know i experianced the same thang with my light dimming i soon found out that it was my battery that was bad i soon bought a 75 dollar new battery from samsclub and i soon checked the inside of my box and it was my wire knocking i fixed those problems now i am sailing smooth a ship on a good day i may not be the best of an audio person but that is what i would do if i was you........<-----just from what i did it fixed my problems..... Edited November 3, 2009 by Dustin Quote Car Owned:2000 Malibu Stereo:Ken-wood kdc 2022 # Of woofers 4 Amp:Ken-wood No capaciters all woofers are 12" Amp wattage 600 watts (SMD) MALIBU CUSTOM AZUL TYPHOON ADDITION OR A.K.A___M.C.A.T.A Link to comment Share on other sites More sharing options...
Guest Dave Posted November 3, 2009 Report Share Posted November 3, 2009 try checking the altenater wires maybe you over looked something if i was you i would buy a couple of capacitersto help with the bumping from the speaker.now you quoted the your speakers was knocking well if you have a pretty good gauged wired running on the inside of the box it could be the bass from the speaker knocking the wire around because i know i experianced the same thang with my light dimming i soon found out that it was my battery that was bad i soon bought a 75 dollar new battery from samsclub and i soon checked the inside of my box and it was my wire knocking i fixed those problems now i am sailing smooth a ship on a good day i may not be the best of an audio person but that is what i would do if i was you........<-----just from what i did it fixed my problems..... aappreciate the info ill look into it im gonna try hooking up a charger to it when i run my system to have sufficient power and see if that is the problem if not ill do what you said. the only problem my box was built on a platform and bolted to the frame of the truck and all of my wires are hidden under this platform so its goin to be a serious pain in the ass. im so not lookin forward to this Quote Link to comment Share on other sites More sharing options...
Guest Dave Posted November 3, 2009 Report Share Posted November 3, 2009 i bought this battery when my old batt went bad like 4 months ago and then i got my alt. 2 months afterwards. im thinking somehow i damaged my battery during the time before i got my alt somehow that fast. i know we measured the power and the amp actually came out well over 200 amps with all three goin closer to 300 Quote Link to comment Share on other sites More sharing options...
