aggballeralex Posted November 5, 2009 Report Posted November 5, 2009 I'm looking to go bigger very soon but before I begin to make any purchases I have to be sure that I will be able make the power needed. I want to install (2) Orion Hcca 12.2's in my car with around 4kish+ RMS. I drive a 2005 dodge neon srt-4. The problem is my stock alt(140ish amp i believe) is controlled by the factory computer. If i were to purchase a H/O alt would this then mean I would just pull codes and my amps be pulled down to a factory level? Is there a way to run this setup without the H/O alt and just run with some extra batts? If anyone has some suggestions on setups it would be greatly appreciated. Thanks for any help, been learning ALOT here. aggballeralex The Build
Steph3n1 Posted November 5, 2009 Report Posted November 5, 2009 I'm looking to go bigger very soon but before I begin to make any purchases I have to be sure that I will be able make the power needed. I want to install (2) Orion Hcca 12.2's in my car with around 4kish+ RMS. I drive a 2005 dodge neon srt-4. The problem is my stock alt(140ish amp i believe) is controlled by the factory computer. If i were to purchase a H/O alt would this then mean I would just pull codes and my amps be pulled down to a factory level? Is there a way to run this setup without the H/O alt and just run with some extra batts? If anyone has some suggestions on setups it would be greatly appreciated. Thanks for any help, been learning ALOT here. if you dont wanna fry yur vc's every month then yea yur gonna want to go with a H/O alt go to DC power they have soe of the most badass alts around from what ive seen 2005 Ford Ranger Reg cab Build in Progress T3 Audio T2000 12 ARC SE4000 Stinger HPM 1/0 Wire DC power 270xp Batts: 1 Redtop up front and a Stinger SPP2250 in the back Hopes to be in and around a 150....weel see my youtube channel http://www.youtube.com/user/steph3n1 Team DBs (Driven By sound)
Iraggi Alternator Posted November 5, 2009 Report Posted November 5, 2009 Yes, you can run a higher amperge alternator even tho the voltage is controlled by the computer. We have alts up to 320 amps for your Neon. PM me for details. Iraggi I'm looking to go bigger very soon but before I begin to make any purchases I have to be sure that I will be able make the power needed. I want to install (2) Orion Hcca 12.2's in my car with around 4kish+ RMS. I drive a 2005 dodge neon srt-4. The problem is my stock alt(140ish amp i believe) is controlled by the factory computer. If i were to purchase a H/O alt would this then mean I would just pull codes and my amps be pulled down to a factory level? Is there a way to run this setup without the H/O alt and just run with some extra batts? If anyone has some suggestions on setups it would be greatly appreciated. Thanks for any help, been learning ALOT here.
aggballeralex Posted November 6, 2009 Author Report Posted November 6, 2009 I'm just worried that if I purchase the alt I will get it on, throw codes and see no gains because it is getting controlled back down by the computer. Can anyone enlighten me more about this? Also what size alt would you all suggest for this application? aggballeralex The Build
Iraggi Alternator Posted November 6, 2009 Report Posted November 6, 2009 Thats not going to happen. The computer controls voltage not current. Your voltage will be same as stock but you will have double the current available. I'm just worried that if I purchase the alt I will get it on, throw codes and see no gains because it is getting controlled back down by the computer. Can anyone enlighten me more about this? Also what size alt would you all suggest for this application?
aggballeralex Posted November 6, 2009 Author Report Posted November 6, 2009 Thanks for all your help so far Iraggi. I understand what youre getting at now. With the factory alt and an extra batt or 2 in the trunk people are seeing very noticeable voltage drops at even 1500w rms alone. I feel I could maybe get by that with the correct alt/batt combo. Anyone here have a suggestion on what size alt and batts? Thanks for all your help, just trying to get a good understanding of what I am going to need before I start my build in a month or so. aggballeralex The Build
Iraggi Alternator Posted November 6, 2009 Report Posted November 6, 2009 With the extra batts their drop will be more with a factory alt. The batts are pulling the alt down even further from the charging current. Now if you have an Iraggi Alternator and extra batts your fine. The alt can handle the extra charging current of the batts and current of the amplifier. Iraggi Thanks for all your help so far Iraggi. I understand what youre getting at now. With the factory alt and an extra batt or 2 in the trunk people are seeing very noticeable voltage drops at even 1500w rms alone. I feel I could maybe get by that with the correct alt/batt combo. Anyone here have a suggestion on what size alt and batts? Thanks for all your help, just trying to get a good understanding of what I am going to need before I start my build in a month or so.
Iraggi Alternator Posted November 6, 2009 Report Posted November 6, 2009 Oh ya.. No problem for the help.
aggballeralex Posted November 6, 2009 Author Report Posted November 6, 2009 Awesome. I'll be contacting you within a few weeks to setup an order on an alt + batts! aggballeralex The Build
