lol, u'll be better off to simplify the equation of quantum physics
but good luck with this
:rofl: Thanks. I needed the laugh.
Oh, and I'm ever closer. My most recent draft of the formula says Meade could hit a 157 sealed up at the dash off of ~ 16kW. A little less than it took him to actually hit that score (according to what I found).
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
use my car as a proof
3 18's, 4500wrms, 148.7 db best
theres so much more than cone area and power that figure in to the output. an 8th order can have 15-20db of gain over a sealed box once the transfer function of a car is worked in. even a ported box can make a 10-15db difference.
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
LOL. What, the thread or my though process? :D
BTW, I think I'm even closer. Assuming the TL mic is approx. .3" in diameter, then the formular works! I'm kinda happy, but don't want to celebrate too early.
Thanks man.
And that info completely blows the formula out of the water. LOL. Oh well. But then agian, maybe not.
Oh, and yeah, SPL is logarithmic. That's part of my formula.
No prob. I would be interested in seeing ur formual tho, being a phys/math person i might be able to help....one thing u could do is derive an equation on how much preasure it takes on the diaphram on the mic sensor to create a certain spl level...but the actauly power/cone area to creat that preasure is deff somethign no forumla can explain
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
Cool. I'll try.
I'll have to post a scan of the paper I'm using tomorrow.
Thanks for the help.
15.4" widescreen
What it does:
+/- 5dB is the difference between me having a 150 or barely being able to do the 39.9 bass race class so I don't think your formula will be quite as accurate as you think.
still pretty interesting to figure out your own formula... props :good:
Wouldnt be thehoe92 without teh purple
Posted (edited)
Thanks man.
And I know it's not that accurate, but that's the maximum error I'm going to allow myself in the final formula.
I'm going to sleep on it and work some more tomorrow.
thanks for all the replies, they've been helpful.
Edited by 1992Chevy K1500
15.4" widescreen
What it does:
Even though this would hardly ever be accurate. unless you were able to get cabin volume, frequency, vehicle flex and random little things in it, but would still be off
but.. what should get done is have the formula posted for all the little noobies that come on and ask if i got 2 btls on my hifonics 2010, what db do you think ill hit?? they wont think anythin of how it could be wrong hah
LOL.
Unfortunately, that's the problem. I figured it out in my sleep. Basically, you need to include the following:
vehicle interior space, distance between the subs and the mic, number of woofers, cone area, xmax of subs, area of the mic's diaphragm (or whatever it is that measures pressure), area of the opening to the diaphragm (assuming it's in a nearly sealed box with one small hole in it; hard to explain, but it's important), location of the port, port area, internal box volume, objects that might reflect the sound pressure from the mics (seats, possibly dash, etc.), any air leaks (no matter how small), how many air leaks, location of air leaks, how much air moves through the air leaks in a given time, temerature, moisture content (air is easier to compress than water), power going to each sub, and any potential flex.
A lot more than I originally thought. :o
Thanks for the input though, it helped.
15.4" widescreen
What it does:
How about 2 10" subs
and 4krms total
does a 153.4 legal
or 4 15" subs
8krms
does a 151.3 legal
  • Who's Online   0 Members, 0 Anonymous, 2312 Guests (See full list)
