dakidd7891 Posted November 18, 2009 Report Posted November 18, 2009 yea my manager asked me to install 2 12'' type rs in his accord, but im not sure i can take apart his dash. anybody have pictures? NEW ORLEANS SLAP Alpine CDE-103BT 2 12'' JL Audio W3v3-4 Hifonics HIF1500.1
neworleanssounds Posted November 18, 2009 Report Posted November 18, 2009 yea my manager asked me to install 2 12'' type rs in his accord, but im not sure i can take apart his dash. anybody have pictures? *Unsnap and remove shift lever trim ring. *Unsnap coin tray/ashtray from assembly and remove. Rubber cover may come out first but entire assembly must be removed to access screws below *Remove (2) Phillips screws from under coin tray/ashtray and remove entire assembly *Remove (2) Phillips screws from bottom of pocket assembly and unsnap and remove *Remove (2) Phillips screws facing up under radio/climate control assembly *Push and hold the hazard button down. Carefully insert a flat blade screwdriver into the slot below the button and push down to release the center clip========push straight down with screw driver make sure you are pushing straight and not angled or you will break button *Unsnap and remove upper panel (including a/c vents) and remove (3) Phillips screws behind the panel *You can use a hook tool to grasp the panel inside of the vent and pull toward the rear of the vehicle. Be careful not to scratch the panel *Unclip and remove radio/climate control assembly. and your done
dakidd7891 Posted November 20, 2009 Author Report Posted November 20, 2009 *Unsnap and remove shift lever trim ring.*Unsnap coin tray/ashtray from assembly and remove. Rubber cover may come out first but entire assembly must be removed to access screws below *Remove (2) Phillips screws from under coin tray/ashtray and remove entire assembly *Remove (2) Phillips screws from bottom of pocket assembly and unsnap and remove *Remove (2) Phillips screws facing up under radio/climate control assembly *Push and hold the hazard button down. Carefully insert a flat blade screwdriver into the slot below the button and push down to release the center clip========push straight down with screw driver make sure you are pushing straight and not angled or you will break button *Unsnap and remove upper panel (including a/c vents) and remove (3) Phillips screws behind the panel *You can use a hook tool to grasp the panel inside of the vent and pull toward the rear of the vehicle. Be careful not to scratch the panel *Unclip and remove radio/climate control assembly. and your done thanks alot man. are u a business in new orleans or is that just a screen name? NEW ORLEANS SLAP Alpine CDE-103BT 2 12'' JL Audio W3v3-4 Hifonics HIF1500.1
