anyone own a SS trx2000d?
dcsoundlabMN
Sometimes you can tighten down on the bare wire with a zip tie and fit it into tighter spots. Never tried it but have seen it recommended on here.
EDIT: either that's a typo or that amp is seriously BS'ed with ratings. 110 at 4 and 2000 at 1? something's not right there...
DOUBLE EDIT: Soundstream site says 1000@4 1500@2 and 2000@1.
Too many projects, too little time...
ya i was slightly surprised when i found out it was 4 ga. but i guess it is only 2k rms. isnt that cheap though? says msrp is 699
02 Chevy Trailblazer
18" DC XL
build in progress...
refs: ak1167 (bought tweeters from)
Yeah these amps are great! We used two of them on two of the SS T5-12 in a DB drag and posted a 149.7. Just make sure you have a stout electrical system they are power hungery!
The Shoe Maker without shoes!
I read somewhere that someone clamped one at 1700rms, but my guess is that was at closer to 16volts.
Technical Specification
* RMS Power Range : 1100 Watts
* Number Of Channels: 1
* Maximum Power: 2000 Watts
* Low Frequency response: 15 Hz
* High Frequency Response: 250 Hz
* Built In Crossovers: Yes
* Channel Separation: Yes
See it uses the term max power in the first set of specs, then a bit down it uses RMS, so I believe it would do around 1500-1700 or so if you could keep the volts in the mid to high 15's.
¿ǝɯɐƃ ǝɥʇ
where u seein that? this is what i see
* Tarantula series Mono Amplifier
* RMS Power @ 4-ohm: 110W x 1
* RMS Power @ 2-ohm: 140W x 2
* RMS Power @ 1-ohm: 2000W x 1
18" DC XL
  • Who's Online   0 Members, 0 Anonymous, 763 Guests (See full list)
