2,500-3,000 RMS or something close to this power!
03navi
Are you trying to replace this amp or add to it? because I don't see why you would need something different when that amp is so close to what you want. Is something wrong with that amp?
ok so i already have one kicker zx2500.1 i need another amp that does close to what the kicker does!
i dont need this amp instead of just putting it in my garage for ever i might as well trade it it!
and also i wouldnt look good haveing two diffrent brand amp!too much power for me!
thats why i wanna trade it for something of less power!
i dont care if i get ripped off with a 2500 wrms amp for my 3600wrms amp!
Vehicle: 2003 Lincoln Navigator
Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust
Amplifiers:Kicker Kx2500.1, MA Audio M700XE
Batteries: 1 Kinetic Hc2400 Battery
Electrical: STOCK Charging System! Tsunami 40farad Capacitor,
Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz)
Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter
Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter
Subwoofers: 2) 15 Power Acoustik Mofo
Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable
Video: http://www.youtube.com/2treo15
So you need another Kicker ZX2500.1? Because I don' think it's a good idea to mix and match amps from different brands even if they are "rated" at the same power
My Official Feedback Thread
PSN - tech2332
Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
if someone would trade me for an Zx2500.1 that would be great!
yeah i dont either but i would rather have 2 amps rated close to power thatn having 2 with a great diff. in power!
you know what i mean?
bump!
just sell off both of what you have and just get a 5-7krmsamp to run everything...easier than gain matching
Good Piont
  • 3 weeks later...
Im Looking to Trade my HK4000d for something along the line of 2,500-3,000 rms! @ 1 or 2 ohm!
For ex.(Kicker zx2500,kx2500,Orion 2500D,Hcca 2500D,Memphis Mojo 16-MCD2500,MMats D3000!
LET ME KNOW WHAT YOU GOT!
The HK4000d CAN BE EASILY MODDED TO RUN AT 1 OR .5 OHM STABLE
TEXT Me For Info (805) 588-1954
RMS Power @ 14.4V: 3600W @ 2 Ohm
RMS Power @ 17.0V: 4000W @ 2 Ohm
Dimensions (W x H x D) 12.4" x 2.71" x 25.86"
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
GOT A QUESTION (PM) ME!
BUMP
  • 1 year later...
  • Who's Online   1 Member, 0 Anonymous, 1399 Guests (See full list)
