I was wondering if its normal for my volt to drop to 12.9 and goes back up? The only time it does this is when truck is at idle or at night with lights on. I have a 220 amp. Iam running a MB Quart 1000.1 and a kicker 650.4 and 2 12's. Any idea
jrplayer36
what is your voltage like while driving? (above 2k)
what kind of battery do you have?
if it only does it at idle than i wouldn't worry about it. most HO alt make their power above 2k rpm and not much at idle
It is at 14.5 to 15.1 at 1500 rmp and a red top under the hood.
jrplayer36
i wouldn't worry about it at all then.
at idle the alt is just spinning very slow, then add the fact that your headlights are on and you will have voltage drop
12.9 is still a safe voltage for those amps.
i would add another red top to the mix...
Full eclipse system is next on list.. soon to gut and redo the honda as new project/rolling buissness card :)
i miss the sound of those old school strokers on beast amps :(
i don't see the point. if you have the money then spend it on another battery.
but....
seeing as how you aren't dropping below the resting voltage of the battery, i don't think another battery will do anything.
its the alt that isn't providing the juice at idle
it depends on where the batteries float at. if it floats at 12.8 or 12.6 then it is still the alternator giving most the power. If the battery floats at 13volts then its power from the battery.
SPL-Lab REPCar: 1996 Honda Accord F22B1 CoupeSuspension: Megan Racing Full Street Coilover Dampener KitAlternator: DC Power XP 270Batteries: XS Power D5100 & D3100Wiring: KnuKonceptz & 2/0 Welding cableHeadunit: Kenwood KDC-MP642UComponents: Hybrid Audio ClarusAmplifers: Lanzar OPTI250X4Subwoofer: 2 Sundown Audio E8.v2Deadener: Sound Deadener ShowdownSPL Meter: SPL-Lab RTA Pro meterWant an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.CA ref: (enellz, 92c1v1c, el_chupo_, Thixx, Kraudio12, SethPhillips, NJack2AF, JamesKarr, ExpoSport, 01 S 10, wgsj_fortvalley, fast306stang, Lakota, blackga, TheLow, adrian1185, the727kid, rudy, sundownz, lmllopez, traksta15, gentlejax, satchel50207, Bigthangs, Goindef154)CACO ref: (extremechevyman67, ghostmechanic, FatBoy2, TheMan007, bdufner, 350zkid, ironb, bmansbach)SSA ref as phi: ( shizzzon, porkchop, onebadmonte, stevemead, TRP, ///M5, denim)SMD ref: (DC Power Rob, Nathan@XSPOWER, Jman08)And then some.
If your alt doesn't have an overdrive pulley, you might want to check one out.
truth. it will give you higher idle rpm's out of your alt. and possibly even higher max amps
even if it floats at 13 volts. he will only gain maybe .2 volts at idle. MAYBE
  • Who's Online   0 Members, 0 Anonymous, 3000 Guests (See full list)
