Hey i am running two kick comp 12inches. with a Hifonics BXi1610D. I found it weird that it has two speaker outputs. I have each subwoofer wired to 2ohms. Do i connect one subwoofer to each output? I thought it was kindof weird. My kicker mono amp only has one output. So i wanna make sure that each is getting the 800watts. Thanks for your time!!!!
Hey i am running two kick comp 12inches. with a Hifonics BXi1610D. I found it weird that it has two speaker outputs. I have each subwoofer wired to 2ohms. Do i connect one subwoofer to each output? or do i bridge the two. I thought it was kindof weird because my kicker mono amp only has one output. So i wanna make sure that each is getting the 800watts. Thanks for your time!!!!
ok well, what you want to do is find out what ohm your subs are,dual voice coils?
click on this woofer wiring link and put in your info and it will show you different ways you can wire your subs..
1ohm load,2ohm load,4ohm load etc,the lower the ohm load,the more power you will get out of your amp.
make sure your amp is stable for the ohm load you have chosen,usually meaning make sure its 1ohm stable before wiring your subs to 1 ohm.
and also make sure your subs can handle the power your amp will put out at that ohm load.hope this helps!!
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp#
2001 Black Monte Carlo SS chrome 20''
(1) Alpine i-9881 deck-ipod-
(2) DC lvl 4XL 18''s-Walled-
(1) DAT Hellfire - 2500.1-fused-
(1) D3400 XS Power battery-fused-
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
(1) DC POWER ALT INSTALLED BY ROB FTW,Big3
(1) Viper 5901 Alarm + killer yorkies and chihuahas
[EdgarCervantes] 4:31 pm: im in my room and out of nowere i hear bass im like oh shit sombody has
bass in this city, i look out the window and its my mom bumping Gorilla Zoe
Wow fast replay and the subs are 4ohm dual voice coil and each wired down to 2ohms each. And yes the amp is 1ohm stable Its just weird that a MONO amp has two outputs.. ill make a picture in paint!!! this is how i have it set up currently...
I just find it weird it has two speaker outputs
damn its late and i need to go to bed,because i thought you were asking how to wire your subs together lol
so what your saying is that your amp has 2 negative and 2 positive outputs.
and you want to know how to connect the speakers to your amp... =)
im not sure myself,ive never had an amp like that
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
ya its messed up!!!! Ive installed 3 car audio setups and have NEVER seen this before. and yes it has two + and two- just like a two channel amp has. I want to make sure the amp is putting out 1600rms well probably noot because its hifonics but still. want to make sure its seeing 1ohm
well once people start waking up im sure someone can answer your question,as ive seen a lot of these amps being used by SMD members,
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
Cool man have a good night and thanks so far!!!
np,
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
